Rockford Fosgate
Discussion in 'General Car Audio Discussions' started by RFP3, Jun 12, 2009.
  1. RFP3
    RFP3 Full Member
    I have a couple question involving Rockford's Power series. I have 3 P3's right now that I love but I'm considering an upgrade to the T2's. First of all, there is a dual 2 T2 and a dual 4. They are rated to handle the same power, and are priced the same, but what difference does that make? And I'm wanting to pair the T2's with the T20001bd amp. I've read that the amp provides more power than it's rated for. Would i be better off with smaller amps or will the subwoofers handle the amps? Any help will be greatly appreciated.
  2. DatDude08
    DatDude08 Full Member
    If you have a dual 2 sub then that means you can wire it for either a 1 ohm or 4 ohm load on the amp. A dual 4 sub gives you the option between a 2 ohm or 8 ohm load.
    That amp is rated to do 1500W @ 2ohms and will do more (my friend has this amp and its a beast). The T2 subs are rated for 1000W rms so two of them wired for a 2 ohm load should be fine, which means you should get the dual 2 models and wire them as such.
  3. RFP3
    RFP3 Full Member
    Would I be better off getting 3 T10001bd and the dual 4's and wiring them at 1ohm or would that be too much overload on those amps?
  4. aznboi3644
    Before you upgrade anything components. Upgrade your enclosure if you haven't already.
  5. RFP3
    RFP3 Full Member
    If my measurement is correct I have around a 7.75 cu. ft. enclosure and that is enough to accomadate the T2's.
