Rockford fosgate help!!
Discussion in 'Car Subwoofers' started by whikid, Apr 20, 2011.
  1. whikid
    whikid New Member
    hi there every one im new on here and was hopeing this would be the placce to find some help.
    i recently got back in to car audio and even after 5 years out and being 26 years old , im still chaseing massive low tones haaha.
    i started my system with a terminator seiries set up from mtx, consisting of 2 4 ohm mtx 12" subs and one mono block terminator 250/1 amp. it was great but nothing compared to what i remember haveing. {3 jl w3's in a power wedge box wired in parralel with a audiovox prestige 1000w} so alas i started craigs listing for better set ups....
    what i found was a rockford fosgate t112d2 for 50$ in great shape. so i made a box very close to website specs , and hooked up my terminator amp to the sub {the sub was wired for 1 ohm at that point} when i turned it up just a little bit... the amp freaked out and started distorting the sub sumthin feirce. i pulled the sub and rewired for 4 ohms....the 2 oohm terminator did fine on that...but at 4 ohms it barl barly pushed that t1 at alll....so i hit the craigs list again...and found an alpine mrp-m350 new in box for 40 bucks.... said it ran great in reviews...i belive even one from thiss site....however im still not able to wire my sub to run 2 ohms due the the fact that it is a dual 2 ohm vc.... i can only do half {1 ohm} or double {4 ohms} so the alpine that can push 350 rms at 2 ohms is now pushing 200 at 4 ohms.... wich is louder than the terminator amp at 4 ohms.... but not enough.... ....
    SOOOO heres my question...... i wanna get the most out of this beast of a woofer...i want its 2 ohm capabilitys.... i think iv found a way...
    if i run the terminator amp to one side of the vc and the alpine amp to the other side.... id be runing the sub and amps at 2 ohms right? i know the terminator will do 200 rms at 2 ohm, and the alpine 350 rms at 2 ohms..... so what im scared of is mis tuneing the wattage out put to each side of the sub? can any one help walk me through how to tune the 2 diffrent wattage amps to the same wattage? and if they are slightly off ....will it dammage my sub?
    best i can figure is turn the terminator all the way up for its full 200 and try to match it with the alpine? the t112d2 can hold a steady 600 rms at 1 ohm i belive? mabe 2 ...but either way 400 would be just right i think.
    any help or opinions would be great.... the only other thing iv thaught is to buy and exact other alpine amp..but id like to get away with the 2 i already have.
  2. fstrfvo
    fstrfvo Full Member
    just run the alpine at 2 ohm and go from there, what your talking about is crazy. Use that amp and save your $$ to buy a new one that you will be hapy with.
  3. des343
    des343 Full Member
    you have never came close to actually powering your set ups maybe if you just get a better amp and the right box...
