Ring terminal/battery
Discussion in 'General Car Audio Discussions' started by cool9, Aug 2, 2006.
  1. cool9
    cool9 Full Member
  2. TheViking
    "rubber seal" what do you mean? a boot over the terminal or something actually on the bolt?
    If its a boot over the terminal, cut it off, or slide the wire/terminal through where the factory wire goes.
  3. cool9
    cool9 Full Member
    A boot. It's put there for a reason to prevent arcing if anything metal comes near it. Maybe I'll go to Pep Boys and get some advice.
  4. Hautewheeler
    Hautewheeler Full Member
    those rubber boots usually end up in the trash. You don't need it if you're careful about using tools near the battery. You can fabricate a new, larger one to cover the ring terminal, if you want to.. I just modified the one I already had..
  5. cool9
    cool9 Full Member
    Thanks for the advice. I could probably find a more suitable one on the net or Pep Boys.
