hi all, well i finally have everything i want to put in my car , so i ran all my wires,soldered everything up, & thought i would give it a pre-run to check things out & PRESTO!! My right RCA input on my MTX RTP202 has a short or cold solder joint on it as if i push downwards on it, it works but as soon as i release pressure the right channel cuts out. I`m so discouraged. any help would be appreciated thanks
yeah, just have the problem with the rear level to correct & some mounting & wire cleanup in the rear & i`ll send some
