would this amp work all shnazzy like http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14934 with these subs? http://cgi.ebay.com/2-ALPINE-SWR-12...5020066QQihZ006QQcategoryZ18803QQcmdZViewItem or would you recomend something else? and what should be the measurements for the box because i plan on making one.
I really like those kenwood amps and those subs...that would work very well What kind of box do you want??? sealed?? ported?? bandpass?? How much space do you have to work with??
sealed box i'm thinkin bout making it outta fiberglass boards but not sure yet i might just make it outta wood and cover it with some type of swade cloth or somthing. i just dont want to buy those subs and amp. then end up with a weak thump.
That amp and sub combo will surely thump. And fiberglass boards would not at all be strong enough for a box...unless they are 2 inches or thicker and heavy bracing...A simple MDF box will suffice. If you want the most thump I'd go for building a nice ported enclosure for those babies
