Hey guys i need a tri set (yellow white and red) rca female ends and the other half instead of being plug ends to be stripped wire ends with pos and neg. Sorry if this is hard to understand im not quite sure how to explain it...
i could but id rather not my factory nav radio has an aux in ability i need to connect those wires into the stock wire harness, and id rather not have the bare wires of the ground in the rcas hitting anything (usually rcas have the pos wire cased inside the rca and the neg is wrapped around it
yeah but the ground is connected with a wire also...the pos is the middle and the neg is the outer shield right???
yup but to get to the pos to separate it from the neg id have to cut the shield which would expose the ground
just start with a longer cable than you need so you can practice cutting just the outer jacket....the inner jacket is the easy one. may i ask what you are planning to with such a cable?
my car has a factory nav option im installing the factory nav that nav has an aux input which i can gain buy grounding a wire and by connecting some rcas to act as the audio and video ins all the rcas ive ever seen have the positive wire shrinked with the ground wire woven around that then a final shrink around that ive seen rca male ends with instead of the neg and pos in the same shrink case, they have their own like a set of speaker wires.
somebody has to have some laying around where you live? i have some red, white, yellow, that came with a broken xbox i had. would that work?i was going to do the same thing. strip the wires so its some what looks damaged but shouldnt matter. what ya think? http://i217.photobucket.com/albums/cc130/psychoomaniac/random/102207_233700.jpg http://i217.photobucket.com/albums/cc130/psychoomaniac/random/102207_233601.jpg
