Quick Easy Question - RCA Wire Size
Discussion in 'General Car Audio Discussions' started by mvargas08, Sep 19, 2006.
  1. mvargas08
    mvargas08 Full Member
    I want to change the RCA cables inside my car that goes from the radio to the amplifier that lays in my trunk. I have a Honda Accord which measures about 189.4 inches, which is 15 feet. Should i buy an RCA cable that is 16 feet or will i be playing it to tight? Should i just go with a 20 feet RCA cable or will the 16 feet be fine?
    Thank you.
  2. TheViking
    16 should be fine
  3. pedro quiroga
    take a tape measure and follow the route of the cable.that way you know how long of a set to buy.
  4. TheViking
    Its a honda acccord, , it will be long enough!!!!!!!
    It aint no darned land yaught with 243' of space to run a cable/
    if you want, get the 20 footer, just will allow ou more room to mount the amp. if you do get a 20 footer, make sue to not tie up t he excess cable near the power wires, or, if you like engine niose, wrap the rca aroung the power wire, that oughta git er dun!!!LOL!!!
  5. mvargas08
    Thank you guys, the help is greatly appricated.
