How do you connect the wire to this inline fuse holder? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...item=5718354380 I can see how the fuse it put in, how to the wire connect?
On the top left and bottom right of the pic there are holes in the plastic, the wire will go in through those holes and there will also be holes right there in the metal blocks. Once the wire is in the metal blocks there is a screw on the side of the block that you screw in with an allen wrench to hold it in place. If you look at the top block on the left hand side you can see the allen wrench screw (it just looks like a hole in the metal from that angle). Pretty crappy explanation, but did it get the point across?
