question???
Discussion in 'Car Stereo Amplifiers' started by jmenace_thakidd, Mar 9, 2007.
  1. jmenace_thakidd
    jmenace_thakidd Full Member
    what is the difference between a/b and d block amplifiers
    i been tryin to figure it out but i dont know can someone please help me out
  2. DaveDSMer
    DaveDSMer Full Member
    just to make things simple.. class D is more efficient than A/B = less current draw from your electrical system to make the same amount of watts.
  3. jmenace_thakidd
    kool kool so if im running two subs and want to use to mono amps which one do u suggest i use?
  4. DaveDSMer
    well.. what subs? voice coil and ohm set ups? price range on the amp?
  5. jmenace_thakidd
    i unning kicker comp VX subs RMS 750
    dual 2 ohm coils
    im lookin to spend rround 400 for a amp
  6. DaveDSMer
    http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3195
    or.. for a few bucks cheaper..
    http://www.millionbuy.com/soupca3500d.html
    that is an amazing find.. that amp for 400 bucks is more than worth it. I cant find it anywhere else for less than 500 bucks and that includes ebay.
    That PCA3500D can run both of your subs without even breaking a sweat.. hell it could run 4 of them if it needed to. But look at it this way.. you will not have to upgrade your sub amp .. like ever..
  7. pedro quiroga
    he may not have to upgrade the amp,but his charging system will have to be for sure.
    will dual 2 ohm coils he may want to wire then into a 2 ohm mono load.because finding a 1/2 ohm mono stable amp for 400 is next to impossible.
    that soundstream IS a deal but he will have to spend more than he may have for upgradeing the rest.
  8. jmenace_thakidd
    i like the soundstream pca3500d and a great deal
    thanks for the find
  9. pedro quiroga
    read up on the big 3.
  10. aznboi3644
    and read up about capacitors
  11. jmenace_thakidd
    got ya i already got the big three read up im gonnalook ito capacitors in a minute
