Quantum Audio Amp for 2 12" Type-R's?
Discussion in 'Car Stereo Amplifiers' started by Fatty209, Dec 19, 2011.
  1. Fatty209
    Fatty209 Full Member
    Is Quantum Audio any good? I found this amp on craigslist, guy is asking $150 for the amp,
    Quantum Audio Cozmic Series QCA2500D
    * 1 x 1250 RMS @ 1 OHM
    * 1 x 2500 watts peak @ 1 ohm
    * 1 x 1250 watts peak @ 2 ohms
    * Top of the line Components
    * Heat Management System
    * Built in sub-sonic filter
    * High Efficiency Mosfet Power Outputs
    * True 1 ohm stability (other brands write 1 ohm, but when you run them at 1 ohm the amp flips to protect constantly. these are true 1 ohm stable!)
    * Built in Low Pass CrossOver - adjustable at 12 dB per octave
    * Bass Remote Control
    * Class D
    * frequency response: 20-250 KHz
    * THD: .05 %
    * S/N Ratio: Greater than 95 dB
    * Input voltage: 11 - 14.4 volts
    * Adjustable Input sensitivity: .2 MV - 5V
    * bass boost control @ 45 hz - 12 dB
    * dimensions: 12.6" x 2" x 10.9" inches
    I got two dual 4Ohm Alpine Type-R 12" subwoofers, they are rated 500 watts RMS, so with these subs wired to 1 ohm, then this amp should slap them insane right? I just dont wanna buy it if it's complete junk
