I hooked up an amp and is runin fine, but when I hook up speakers to it I'm gettin a hummimg sound out of the speaker. Need help??
humming or whining sounds? that's usually caused by a bad ground... where did you ground your amp to? was it to BARE metal meaning did you sand down there area where you put your ground wire to? how long is the ground? another possibility would be bad RCA wires.
Grounded into a strut blot in the trunk sand it down, but Ill try new rcas and see wat happens thanks
