I have this sub: Audiobahn 1208Q 12” Subwoofer 12" 1500 WATTS RMS POWER, 3000 watts max DUAL 2 OHM VOICE COIL NE 1/4 OHM OPERATION Should I power it at 1ohm or 4ohm? Id rather just buy a monoblock amp to power it at 1ohm. Is this a good idea? What WATTAGE do I need from a monoblock amp? Specs on amps dont list what RMS power is at 1ohm, so Im confused. For example, would this amp power it: http://www.bossaudio.com/main/817
Welcome to caraudiotalk! First thing we'll have to know is what your budget is for an amp? Don't get a Boss amp, it's real crapola. it doesn't put out rated power. also, what kind of car are you putting this in? what kind gauge wiring will you be using?
http://sonicelectronix.com/item_12210_Hifonics+BXi+1208D.html http://sonicelectronix.com/item_9552_Hifonics+TXi+1508D.html
