Power wire gauge?
Discussion in 'Automotive Electrical' started by maceo, Sep 10, 2007.
  1. maceo
    maceo Full Member
    I have a single 4 gauge wire from the battery. I am adding an amp to power a sub. I purchased a power distribution block. It will accept the 4 gauge in, but the two terminals going out are not large enough for 4 gauge.
    Question: Am I supposed to drop down to (2) 8 gauge wires to power the two amps? Or should I take the block back and get one that has 4 gauge in and (2) 4 gauge coming out?
    Thanks.
  2. danracer
    danracer Full Member
    make it fit lol i have a DB that is tha same so what i did was i cutted some of the strands and made it fit
  3. electrolytic
    electrolytic Full Member
    Umm, which amps? If the amps accept 4 gauge wire i would take that distribution block back and get one with 4 gauge in and 4 gauge out. Unless the amps are only like 100 watts each. More power equals more power lol.
  4. pedro quiroga
    unless your running thousands of watts then a short run of 8 gauge should work for your amp/s.
    i have the same set up 4 in 8 out.my amps dont mind.
  5. G3n3R@1
    G3n3R@1 Full Member
  6. pedro quiroga
    sweet then mine fall right in the 8gauge cat
