power problem
Discussion in 'Car Subwoofers' started by bass-4-life, Jun 5, 2010.
  1. bass-4-life
    bass-4-life Member
    Ok so i been having this problem with my car where it shakes when my system hit a bass note while Im driving. Can't firgure out the problem. My system consist of 2 amps and a 10inch kicker comp subwoofer.
    1st amp is rated at 750w which is for mids and highs.
    2nd amp is rated at 550w which is for the subwoofer and a
    1.5 capacitor but still shake. Can any body on her help me out.
  2. fstrfvo
    fstrfvo Full Member
    What do you mean buy shake? Are you talking about vibrations caused by the woofer?
  3. bass-4-life
    bass-4-life Member
    Yea every time my system hit those bass notes cause by the woofer is like the car is loosing power, like it wants to shut off. ? do i need to upgrade the battery or the altanator, only pushing 1300 watts of power
  4. fstrfvo
    fstrfvo Full Member
    Well if you have a fuel injected car you will have an electric fuel pump. All electric fuel pumps have a certain operating range, most cars are from 9 volts to around 16 volts, so when your bass hits your amp is drawing a lot of voltage and may be causing your electrical system to drop below its normal range which can cause your fuel pump to switch on and off very quickly, or your battery could be dropping a cell.
