Power draw question?
Discussion in 'General Car Audio Discussions' started by The Hamburgular, Mar 28, 2011.
  1. The Hamburgular
    The Hamburgular New Member
    I'm looking at powering two 12" Kicker CVRs with a 900w rms amp @ 2 ohms in my car. I have a 117 amp alt and I'm wondering if that will cause any electrical problems? I've been looking around but I can't find anything on how to calculate the draw on your electrical system.
  2. tommy2tone
    tommy2tone Full Member
    You should be fine,but if your lights dim when the bass hits,do the big 3.You can google search it and find out what it is.
  3. pedro quiroga
    do the big 3 anyways. if it dims you can add a batt in the rear.
  4. The Hamburgular
    If I add another battery would I need to get a more powerful alternator?
  5. pedro quiroga
    i currently have 2 batts in the back of my truck and the one under the hood on a stock 105 amp alt... big 3 too.
    the batt should be as close to the same under the hod as you can find.
  6. The Hamburgular
    ok thanks for the help guys
  7. steve
    steve Full Member
    Here is a simple way to determine average current draw on the electrical system(total rms continous watts x .50 / amplifier effeciency / cars voltage = average current draw on cars electrical system).this is intended for musical signals not tone generators.the reason for multipling by .50 is that .50 represents a musical signal driven to the point of distortion.for bass reproduction you may use (.60).if there is more than one amplifier used,simply combine the results of all amplifiers.
