Power car amps for home juice...
Discussion in 'General Car Audio Discussions' started by CadillacETC1997, Dec 4, 2006.
  1. CadillacETC1997
    so i got all these bose mini amps from my car lyin around
    figured id connect them up and see how they sound
    to be honest i was shocked it make my home audio system sound great.
    so anyways the problem is each of the mini amps are running off 2 9 volts a piece....
    anyway to power these suckers off the wall power so as not to spend a fortune in 9 volts?
  2. CadillacETC1997
    think that will be able to hold up all 4 mini amps?
    i was thinkin of gettin a car battery but i dont want the acid leakin and mom wouldnt much be happy about that on the carpet rofl
  3. pedro quiroga
    im guessing it all depends on the amprage draw from the mini amps
  4. CadillacETC1997
    i have absoultly no clue how much they draw
    but it did take 2 9 volts to get them to come on
    1 couldnt do it
    and those 2 9 volts lasted about 5 hrs steady before dying
  5. aznboi3644
    I'd go atleast 10 amps...Caddy I know u got the money....I bought a 25 amp power supply from Radio Shack last year....works really good
  6. TheViking
    Curious Caddy? How did you determine it takes 2.9 volts to get the amps to work?
  7. CadillacETC1997
    umm
    i tried 1 9 volt
    no worky
    i tried 2 9 volts
    and it came on
    how much did the radio shack one cost?
    im not really cheep i just want one now...
    youd be surprised vik
    for as much as those amps and speaks sucked in my car
    those mini amps on my old infinity ref speaks and 1 powering a kicker solo sub actually bumps and sounds DAMN good
  8. pedro quiroga
    get the biggest you can afford.they werent that much.try the 22 amp model.i'm sure once you start cranking the vol thy will start to pull some current.
    check them with a VOM.then you'll know for sure which size to buy.
  9. CadillacETC1997
    to be honest
    i had the system on full blast and they NEVER cut out
    very clean power and sound i think
    so anyways imma see about buyin the 22 amp model via ur recommendations i think less someone else chimes in with any thoughts....
    any idea of places to buy these sides online i kinda want it now lol
  10. pedro quiroga
  11. CadillacETC1997
    even if it was 2 9 volts 10 should be ok????
    they are from a factory car bose system so i was thinking they might be 12 volts???
  12. pedro quiroga
    the supply is 12 volts but we are talking amprage draw.10 or 15amps should work but im not 100%sure.thats why you should check the current draw on a VOM.
  13. CadillacETC1997
    dont have one to test else i would ya kno....
  14. TheViking
    I have run some car audio equipment in the home before , long term.......
    I used a astron 50 amp power supply and a sealed gel cell battery (no leaks)
    I run an Orion 2150SX on 4 15 inch subs (we had a NICE setup for our jam sessions, (even miced my drums through the subs) the system worked good for about 4 hours then the voltage started to drop off below 13 volts, thats when i quit running it.
    With your application , a good strong power supply of 25 amps should work with NO battery, or perhaps a battery and 10 amp power supply.
    I dont know much about the bose system.
  15. aznboi3644
    My radioshack on costs me about 120
  16. aznboi3644
    So Viking if you wired up the power supply with a battery would it be charging the battery and supplying current...because I'm not really using my power supply anymore and may wanna hook something up in my garage
  17. TheViking
    Yes, the power supply would maintain the charge on the battery, and allow whatever is hooked up to draw from the battery and power supply.
