Polk Audio PADB1224DVC
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, Nov 8, 2010.
    $477.00
    High Performance Package with Two db1240 Subwoofers and a PA1200.1 High Performance Amplifier
    PADB1224DVCHigh Performance Package with Two db1240 Subwoofers and a PA1200.1 High Performance Amplifierdb1240 12" 720W 4-Ohm db Series Car Subwoofer DriverPower Handling
    • 720W Max
    • 360W Rated Power
    • 12" Single voil subwoofers optimized for high performance in virtually any enclosure type: sealed, vented and band pass.
    • Wrap-around Rubber Gasket seals the sub in your enclosure for airtight performance.
    • State-of-the-art laser-based Klippel measurement technology perfectly centers the subwoofer's voice coil in the magnetic field, improving X-max and BL linearity, and the sub's micro and macro dynamics, for deep, precise, bass!
    • Black Matt-finish Composite Cones are unbelievably stiff for real gut-pounding bass.
    • Injection molded ABS dust cap also stiffens the cone to suppress unwanted resonance for incredible low distortion, high impact bass response.
    • Big beefy magnet structure and motor assembly for high output bass with tight control.
    • Durable Butyl Rubber Surround for consistent, reliable performance.
    • Four-layer vented voice coil runs cool while your music stays hot.
    • Vented pole piece for higher efficiency and ultra-high power handling.
    • Fast-On wire terminals for quick, secure hookups.
    PA1200.1 1200W RMS Class D Monoblock PA Series High Performance Car AmplifierPower Handling
    • 400W RMS x 1 at 4 ohms
    • 800W RMS x 1 at 2 ohms
    • 1200W RMS x 1 at 1 ohms
    Performance
    • Monoblock amplifier for subwoofer use and particularly ideal for the SR Series.
    • 1200 watts x 1 (1 ohm), 800 watts x 1 (2 ohm) and 400 watts x 1 (4 ohm) continuous power. CEA-2006 Compliant specifications for true, accurate power ratings.
    • 2400 watts x 1 (1 ohm) dynamic power.
    • 1 ohm stable design can drive even the most demanding subwoofers.
    • Super Efficient Class D Pulse Width Modulation amplifier design. Draws less power and runs cooler so you won't heat up the inside of your vehicle or make the headlights dim.
    • High-speed MOSFET switching power supply and high current Bipolar Output Transistors pump maximum voltage and high current to your speakers or subwoofers.
    • Double Layer Fiberglass Epoxy Printed Circuit Boards for more rigidity, less shrinkage and a smaller overall amp footprint.
    • 6-Way Smart System Protection (SSP) circuits
    Functionality
    • Anodized extruded brushed-aluminum cover for maximum heat dissipation and great looks!
    • Cast aluminum textured end caps for optimized heat dissipation and hiding of connectors. Solid aluminum logo and model panel back lit in cobalt blue.
    • Adjustable 12 dB/octave low-pass crossover (30-250 Hz).
    • Switchable 8 dB bass boost at 40Hz for extra bass thump.
    • Variable input gain optimizes match with different signal sources (250mv to 7.5V).
    • Switchable 24 dB/octave subsonic filter protects ported subwoofers.
    • Switchable 180° phase inversion for easy sub to main integration or external bridge mono operation.
    • Mounting hardware with rubber isolation grommets and extra fuses included.
    • Light Bar/Fan Output- Connect an optional LED light bar or cooling fan for custom installations.
    • Multi-Color Status LED gives instant information on amplifier operation.
    • Remote Subwoofer Level Adjuster included.
    • Master/Slave switch and RCA Outputs for easy daisy chaining of other amplifiers.
    • Master/Slave switch allows parallel operation- master amp's gain and crossover settings will be duplicated in "slave" amplifiers for consistent, repeatable settings.
    • Power and ground terminals accept bare wire up to 4 AWG. Terminals use standard #2 Phillips head screwdriver- no more hex wrenches to lose or strip!
