Please help with a AMP?
Discussion in 'Car Stereo Amplifiers' started by 00thrilla, Jan 26, 2007.
  1. 00thrilla
    00thrilla Full Member
    Got two mtx 8500 thunders, 12inch dual voice coil, rated at 1000 watts peak-500 RMS(each one) now all i need is a amp making atleast 1100-1200 watts? thanks
  2. DaveDSMer
    DaveDSMer Full Member
    whats the voice coil set up. Whats your budget.
  3. TheViking
    Ok, Why not......i will make the assumption that you have a big budget....get an old school Orion 2250 SX or 2100 HCCA, depending on your speakers impedance. Either one will kick ass
    If not one of those, then look to getting a soundstream
  4. 00thrilla
    Budget is anywhere from 500 to 1000
  5. aznboi3644
    Um...what is the impedance of those woofers
  6. 00thrilla
    T8512-44
    Impedance - Dual 4 Ohm
    Frequency - 39-150Hz
    RMS Power (Watts) - 500
    Rec. RMS Amplifier Power (Watts) - 250-500
    Sensitivity - 92.2 dB
    Voice Coil - 3"
  7. DaveDSMer
    disregard this post i am retarded
  8. DaveDSMer
    still retarded with my responce
  9. DaveDSMer
    stick with a mono block.. don't get a 2 channel.
  10. DaveDSMer
    yeah lets go with this one man
    http://www.sonicelectronix.com/item_5647.html
    well fit perfectly and its MTX to match the subs.
    just be careful with your gains as this has more than enough power for those subs. rather have too much in the amp than not enough though.
  11. aznboi3644
  12. sundownz
    sundownz Full Member
    If you have that much cash available in your budget I will second my SAZ-1500D amplifier.
