Okay so i have 2 180w Bumper speakers(will add more info on them when i get them) sitting in my dads house and i want to put them to use,theres one problem though,the car has no space in the front so i thought why not just put them in the trunk? So thats my plan so far,now i was wondering if making a homemade enclosure out of plywood would work well. This will be my first time making an enclosure btw. My next question is what kind of amp can i use for both those speakers? And is there an amp that can power those to speakers plus my future sub? Dont really have a budget to spend on so it will be appreciated if yall stayed on the lowest prices available Thanks
Installing the subs in the trunk will yield better sub bass performance than sitting in the front generally speaking, so that is not a bad idea. however, I would like to recomend the use of MDF or even particle board over the use of plywood. Use 3/4" material. The use of plywood generally is not a good idea...it does not glue up well, does not like screws going into the edges of it, it easily splits out, and can , over time, delaminate and cause really annoying buzzes and rattles when bass notes hit! So lets stick with particle board or MDF.
