Pioneer CDXFM35. Need repair info for Frequency modulator CWM2979.
Discussion in 'General Car Audio Discussions' started by Repairguy22, Jan 18, 2012.
  1. Repairguy22
    Repairguy22 New Member
    Have Pioneer CDX-FM35 CD changer. All functions work as should.
    Does anyone have repair experience with Pioneer?
    This is a frequency modulated unit.
    Have NO volume to head unit. Head unit works as should as radio or tape player. Can turn up head unit volume to max, W/ FM35 on and set to correct frequency. Can hear CD music (very low),
    but no volume.
    What component in CWM2979-(frequency control modulator) has gone bad?
    Is board component available?
    Thanks
  2. steve
    steve Full Member
    possible output power transistor(s) are bad
  3. Repairguy22
    How do I find a replacemrnt O.P.T. I googled the only numbers that are on the component, nothing came back.
    There is no name on the part either. The only specs I have is from the manual, Vdc & amp draw for the entire unit.
    Help!
    Additional post. 3/7/12.
    Tried OPT replacement.
    Still no luck W/ this repair!
    Any other knowlege is welcome.
