Hello, I'm making my first steps in the car audio hobby ^_^ and I need some help. I have a Pioneer TS-W307D4 sub and a Kenwood Kac-726 amp. So I want to make a box for the subwoofer, but i don't want that deep-vibrating bass - what must be the box sealed or not ? On the cover of the sub there are a few sizes for boxes - the sealed one is 35cm cube. I'm listening to rap/hip-hop/house/dance. I'm planning to put the sub in a '98 Ford Focus Hatchback. Technical Specification Sensitivity: 89 dB RMS Power Range : 400 Watts Peak Power Handling: 1200 Watts Impedance: Dual 4 Ohm Low Frequency response: 18 Hz High Frequency Response: 500 Hz Diameter: 12 Inch Features 12" 4-ohm Dual Voice Coil Subwoofer 1200 Watts Maximum Power 400 Watts Nominal Power Double Stacked Magnet IMPP with Aramid Fiber Composite Cone 83 Oz. Ferrite Double Stacked Magnet System 3-Layer Woven Radial Surround 4-Layer, 2.25" Round Copper Voice Coil PI 180 Voice Coil Wire Projected Pole Yoke with Vented Pole Magnet Cover Single Sided Push Terminals Enclosure use: 0.85 cu. ft To 1.75 cu. ft Thank You in advance! Best Regards, Radoslav.
well, the easiest way to go about it is to make a sealed box. since you don't want ground pounding bass you may just want to go with 1.5 cu. ft. sealed box.
yup, 3/4 MDF. Wood glue all the joints and pre drill holes every 3 inches and screw the joints together. I've done two boxes already, it's really not that hard.
