im thinking of geting a set of phoenix gold octane-R R12D. i'd be powering them with my viper d600.1. the woofers are dvc 4 ohm so it let my run my amp at 600rms and the woofers are rated at 250rms each. would this be an ok set up or should i get difrent woofers they begoing in a seal box
That setup should work fine. Just set your gains right and you won't blow those subs. Sealed box will improve the power handling of those subs also so you should be fin as long as you dont just crank everything up.
