Anyone heard anything about this amp? its the CYPAD4003. mad by panasonic, 4 channel, 1100W amp. I am new to car audio and and looking for an amp to power my three MTX 10"s Thnks
It's not a very good amp... what is your budget we can find you a better amp. also what voice configuration are your subs, and what is the rms of them?
•frequency response 37-150 Hz •power range 75-250 watts RMS •peak power handling 500 watts •sensitivity 85 dB Sorry about voice conv. dont know what that means. And Its my first system and im a college kid so i dont wana buy junk, but i am poor ha
what brand subs are they? We understand that you're on a tight budget but how tight is it? how much are you looking to spend for an amp?
they are MTX's and im on a tight budget but im going to spend as much as i have to. the panasonic was a steal at 140 but if i had to i would prob be willing to spend double. I dont really wana spend more than 400 more and i still need a headunit and to install it
got a link to the subs? I need to see the coil configuration so i can suggest an amp. If your on a budget you should be looking at power acoustik amps. very good budget amps...
once again im sad to say ur talking to an audio idiot ha i bought the 3 subs in a box and on the back there are two connectors. a black, and red hub for cables/wires about 5/16" in diameter. i looked at that company and they do have some cheap amps and i heard they are loud from a friend. but i dont understand when you use a mono or 4 channel amp. but im assuming you would need a better answer to your initial question ha
also my buddy who gave me these subs was using a kenwood 1000w. is that a legite amp or not? i have a feeling that these subs could hit harder than they did wiht that amp
All i have to say is find out the exact model (supply a link) so i can check their impedance. Then and only then can we pick out an amp for you. We have to base it on impedance, no. of voice coils and their rated power. Then we have to check how the subs were wired in your present box. I can't just throw amps at you without knowing this information. Kenwood makes a good amp btw.
ill try to get some pics of the box soon and the voice coils and let me know if u need more info on the sub itself or the name is enough.
so, are these the one's? http://www.crutchfield.com/p_236BL104/MTX-Blue-Thunder-BL104.html?tp=111&tab=features_and_specs
here is the amp that was used before i got it http://www.amazon.com/Kenwood-KAC-8104D-1000-Watt-Amplifier-Variable/dp/B0012Z1M18
So i think i narrowed it down between the kenwood KAC-8104D and the KAC-9104D. a 1000W or an 1,800W. Because i plan on adding an additional 10". would a 1000W be large enough to power the 4 10"s
500 watts peak power and your going to add another in a seperate box. Id go with the 1800 watt amp cause they are not very efficient at 85 db, you will need the power to push them.
