painting dust cap **W/PICS**
Discussion in 'Car Subwoofers' started by connerray2010, Mar 3, 2011.
  1. connerray2010
    connerray2010 Full Member
    Ok folks, here is the process that im useing to paint my subwoofers dust cap (my own way and could just as well be applied to the cone the same way)
    *sand 800 grit* *primer* *sand 800 grit* *primer * *sand 1000 grit* * paint color of choice* *light sand w/1000 grit* *paint color* *light sand 2000 grit* *paint color NO SANDIND* *clear coat* *clear coat* BE SURE TO CLEAN AREA AFTER SAND
    that is the process of my choice.
    I will let paint set over night before next coat is applied. (or all day) in warm dry place
    the reson for such high grit paper? cause i didnt want to hurt the cap.
    the reason for this long of a process? hell idk, just sounds good and sanding between layers will give it a nice roughed up texture for the next layer of paint to "cling" on to (sounds good to me lol what about you?) feal free to chime in on stuff you would or wouldnt do.
    pics up in a moment of tap off and first coat of primer.
  2. connerray2010
    BEFORE
    AFTER
  3. sfhellwig
    sfhellwig Full Member
    2 coats of primer, 3 of color and 2 of clear. I'm sure the color will come out very solid. For a sub this is likely to not make a difference. It won't add enough mass to change the T/S parameters. But I would use this cautiously if you ever want to do it on a smaller set of speakers. THAT much paint will start being considerable for a 5.25. Maybe you'll never have to worry about that. Material you are coating will make a difference also. Good luck, look forward to seeing end result.
  4. connerray2010
    [​IMG][/IMG]
    got a little primer on the cone:( but i have a f**k it sticker coming from psi that will go right underneth it on the cap and hopfully look good. kinda adds carictor to the sub lol
    note:spend a little money for painters tap cause black tape dont work lol
  5. TheViking
    You do realize that adding the weight of the paint will change the Fs, Qtc. , and Pd of the sub? It will now only handle 12 watts peak power, and the Fs is now 12 Hz......Recommended box size will be 29 cubic feet and a port 19 inches round at 6 feet.....and the F3 will be 698 Hz.
    Just kiddin man!!!!!!
  6. TheViking
    And you need to clip your toenails........WTF!!!!! LOL!
  7. connerray2010
    they aint that long, after all im from the sticks of AR lol
  8. connerray2010
    and that primmer on the cone looks way wors than what it really is. thinking about painting the cone any way
  9. TheViking
    oh ya....arkansas.....that explains alot! I can say that, I am in the ozarks, so, takes one hillbilly to know another. BTW, speaker looks good
  10. connerray2010
    thanks.
    my box on the other hand looks like it was painted with sticks and rocks for a paint brush. 97 cent rattle can on mdf dont work so well
  11. jonnyv713
    prime it a few times before the paint :cool:
  12. connerray2010
    i did prime it a few times, its like the wood sucks it up like rag in water lol. i think your suposed to you oil base paint but im not sure
