PAC Turbo 1 Line Driver
Discussion in 'General Car Audio Discussions' started by electrolytic, Feb 5, 2007.
  1. electrolytic
    electrolytic Full Member
  2. aznboi3644
    Should work fine
  3. electrolytic
    hey, Azn is that Orion still available? Is it a mono amp? I need one for my subs, they are mtx 10" 400w rms each in a vented box.
    My poor 100 watt esa running at 2 ohms has went into thermal protection about 10 times now and i know i'm running out of times lol.
  4. aznboi3644
    lol how much money are you trying to spend on an amp??
    sorry but I can't remember what Orion amp you are talking about
    what subs do you have??? like what series and impedance??? Guessing single 4 ohm because you have em at a 2 ohm load lol
  5. Ranger SVO
    Not a good Idea, instead increase the volume of the music files themselves.
    If its an MP3 file use MP3 Gain, for other formats there are similar programs.
  6. electrolytic
    MTX MXS1004
    Speaker Type Passive; Nominal (RMS) Output Power 400 Watt; Response Bandwidth 43 - 150 Hz
    Input Impedance 4 Ohm; Recommended Amplifier Power 200 - 400 Wattp; Sensitivity 87.7 dB
    Speaker system speaker type Car subwoofer driver; Speaker system car speaker diameter 10"
    Speaker system nominal (RMS) output power 400 Watt; Speaker system response bandwidth 43 - 150 Hz
    Speaker system input impedance 4 Ohm; Speakers system connectivity technology Wired
    Speaker Diameter:Car Speaker Diameter 10"; Speaker System DetailsSpeakers Included Car subwoofer driver 10" 400 Watt 43 - 150 Hz 4 Ohm Wired ;GeneralDimensions - Diameter:Diameter 10.7 in
    $200.00-$300.00?
  7. electrolytic
    ok thanks, you mentioned you had an orion a while back from your buddys shop or something, maybe it wasn't you lol.
  8. aznboi3644
    Oh well there is an old orion hcca 225 amp but it pumps out an underrated 400 watts at 1 ohm MONO
  9. electrolytic
    Hey Ranger, Can you explain a little more why it's not a good idea. My ipod's battery dies very quickly from being cranked and i don't really want to use any more software than itunes, It's pretty well automatic, no screwing around and it is superfast. Will do one cd in about 4 mins. I'm not going to go crazy with the gains on the pac, just want to boost it enough so it matches when i switch over to cd or radio, It is way out, will blow my speakers if i forget to turn it down then switch to cd or radio. I'm thinking the ipod is only putting out 300mv or something not normal from the headphone jack. Maybe i can measure it with my new meter lol.
  10. electrolytic
    yes, i think thats the one, would it be good for me? How would i get 1 ohm? 3 woofers?
  11. electrolytic
    3 woofers is 1.3333 ohms is that ok?
  12. aznboi3644
    um your subs can handle 400 rms each...I wouldn't recommend this amp...also if something happens and the amp fails than you are SOL
    Those kicker 750.1s have been tested to put out close to 900 watts at 14 volts in a 2 ohm load
  13. electrolytic
    wooooooooooooooooo, i'm literly doing backwards sumersaults with a spiral double twist in the air. I had to grab this don't ask how i'm going to pay for it lol!!!
    ORION CAR AMP RARE BRAND NEW!!! XTREME 900.2
  14. pedro quiroga
    thats a great price for that kicker 750.1.they retail for 589.00 near me.
  15. electrolytic
    I grabbed this from ebay as new!!
    Where's that drunk guy viking lol.
    Orion Xtreme 900.2
    Amplifier Type: 2-channel
    RMS Power @ 4 Ohms: 225W x 2
    THD at 4-Ohm RMS Power: 0.03%
    Bridged RMS Power @ 4 Ohms: 900W x 1
    Speaker Level Inputs: no
    Preamp Outputs: yes
    Built-In Crossovers: HP/LP
    Bass Boost: 0 or 10 dB
    Frequency Response: 10-10,000 Hz
    Signal to Noise Ratio: 100 dB
    Fuse Rating: 2 x 30 amps
    Now my mtxs are not good enough for the amp lol, i guess i need one good woofer at 4ohms for this amp?
  16. electrolytic
  17. Ranger SVO
    If you stay realistic with the gains it will work fine. My son uses I-Tunes (I Don't) and he told me once that I-Tunes has the ability to adjust MP3 volume levels before loading the Ipod.
    My opinion comes from Crank It Up contests. When I used a Line Level amp, my van was not as loud. In fact, it was loudest when running HU's with less than 1-volt pre outs. Yes we had to turn up the gains on the amp, but I think the signal was cleaner. In other words, the amps had a cleaner signal to work with.
    I started making my own demo CD's with adjusted volume levels and to a point it worked. The van got louder. It quit getting louder when my base volume reached 100.5dB. After that the CD actually had a clipped signal (I was using sine wave tones, not music).
    I had the same problem with my Ipod, low volume level. I could adjust the source volume on the HU, but I'm a picky b*tch. So I adjusted the MP3 files themselves so that everything was at the same level.
    I think you'll be OK as long as you don't get carried away with the gain adjustments.
  18. electrolytic
    Cool, I'll just set it and forget it lol, like glade plugins
  19. electrolytic
    Adire Audio azn? lol Would one Tumult handle this amp.
