Oz audio Vector Series VA2000.1 Amplifiers
Discussion in 'Car Stereo Amplifiers' started by thecat666, Nov 9, 2010.
  1. thecat666
    thecat666 Full Member
    I have 2 Oz audio Vector Series VA2000.1 Amplifiers, I’m trying to find out if these amps will run at 0.6 ohms. I know they run at 1 ohm ok, I want to run 8 x 4 ohm subs to each amp final load 0.6 ohms.so can anyone tell me if they will take it.
  2. Klinkster
    Klinkster Full Member
    Its only rated to 1 ohm, so I personally would not risk it.
    Taken from the OZ spec page:
    * Designed and engineered in the USA
    * Class D operation
    * Oversized high current multi-stranded power torroid
    * 1 Ohm stable
    * Oversized capacitor banks
    * Adjustable low-pass X-Over (50Hz-250Hz)
    * Adjustable subsonic filter (20Hz-50Hz)
    * Soft turn-on & turn-off circuitry
    * Remote bass control
    * Two amplifiers can be “strapped” for huge power gains
    * Master & slave inputs / output
    * Gold-plated inputs, outputs and RCA jacks
    * 1/0 gauge power & ground inputs
    * 8 gauge speaker outputs
    * Three-year warranty (when purchased and installed by an Authorized Oz Audio Dealer)
    Here is a link for the user manual:
    http://www.rawedge.com/ozaudio/docs/manual_amplifier_vector.pdf
    I would suggest this option to be sure-
    As stated in the user manual:
    If you have any questions or concerns contact your local authorized dealer or call Oz
    Audio Technical Support at 561-998-0211.
  3. ericj
    ericj Full Member
    I agree with Klinkster. I'd only run a .6 load on a 1/2 ohm stable amp. A 1 ohm stable amp won't fare well at .6 ohms.
  4. jonnyv713
    Id do it. Imp rise will put it above 1 ohm. If you have a good electrical, you will be fine I bet. Dont be stupid though. Keep an eye on it and make sure it doesnt get really hot.
  5. monster71
    monster71 Full Member
    Am i reading ur post correctly? 8 x 4 ohm subs per amp. 2 amps. So you will be running 16 subs? How many batteries u gonna run? 4000 watts of bass is a power hungry animal. And like johnny said. They r going to get very hot. The specs dont list any internal cooling fans.
  6. thecat666
    i have over 300ah at the moment will be adding 2 more batteries,they say 75ah to 100ah per 1krms. i would have thought that 300ah would be enough to start with but am unsure,also how do you go about working out imp rise.this is my daily ride used most days of the week, i really dont want to blow amps so i may have to run in 2ohm loads which means around 1000 - 1100 rms per amp so 8 subs each amp.thanks guys for the help so far.
