If I were to get this amp (which I'm really liking the idea) http://www.sonicelectronix.com/item_9798_Rockford+Fosgate+POWER-1000.html I'd like to use all of the 5 channels into a 2 ohm load. Easy enough with the bass channel (through either the correct speaker configuration, or dual voice coil speakers) and the same goes for the mid base drivers (as I'd really just be using small, 8" subwoofers for that anyway. My question is though, how do I get my seperates (tweets and mids) to provide a 2ohm load to the other 2 channels ??? I believe most of these are 4ohms out of the box, huh ? I mean, if I had to double up on my mids and highs, it might not be such a bad thing anyway.... except for the extra cost, and trying to find other good spots for them to be mounted. Suggestions please.... Thank you, Fish
if i were you, i would buy a set of coxials to put in the stock location then a set of good components to put in a pair of kick panels. if you want, you can try to make the kicks yourself, but you can also buy them. They may be quite spendy too. just make sure the 2 sets of speakers you choose for up front have the same sensitivity otherwise the speaker with the lower sensitivity will be over powered by the other set.
