i just got two old school kicker l5s. they are the black ones. dual 4ohms. ive got em in a sealed box not for sure the size of the box. but anyway i got a nice kicker ix2303 amp running em at 1ohm. the reviews say it does like 720 in bridgd mode but im not for sure the amp does not go into protect mode but i barely have it turned up. can anyone give me some more info on this amp and how i should run my setup. ive got memphis pr 5x7s up front and infinity 5x7s in the back. its in a extened cab ranger. pionner head unit. thanks yall
That amp isn't rated for 1 Ohm loads. I think it is 230x2 at 4-Ohms, 360x2 @ 2 Ohms. You can't bridge the amp. Run it in 2-channel mode with each woofer parallel and you should be fine at 2 Ohms.
