/ Register
Ohm Questions for Noob.
Discussion in 'General Car Audio Discussions' started by crackerjack, Apr 24, 2006.
  1. crackerjack
    crackerjack New Member
    OK. I have 2 dual 2 ohm l7 12s wired in series to 2 ohms. My amp is a DEI Viper 1200.1d. I'm a little confused though, it is supposed to be a mono amp and it has 2 channels. So I bridged the amp (which I didnt think was possible on a mono amp). The amp manual said something about the amp being wired parallel inside it or something. I AM SO CONFUSED. Some help would be great.
  2. Hautewheeler
    Hautewheeler Full Member
    if the amp is a mono amp, then it just has two outputs -(parallel outputs that are not in stereo). bridging them will do nothing (unless you reverse polarity on one side - not recomended!). if you have two 2ohm subs in series, then they are at 4 ohm. disconnect what you have setup, and wire each of the subs to it's own output from the amp.
  3. aznboi3644
    Hautwheeler is correct. The amp only has two outputs for multi-sub connections. Doesn't matter which + or - you use. Is that amp 1 ohm stable or 2 ohm stable?
