oh nooooooo
Discussion in 'Car Stereo Amplifiers' started by daimond16, Feb 24, 2007.
  1. daimond16
    daimond16 Full Member
    oki just broke off the little needle in the middle of my rca wire tip and its stuck in the amp what should i do
  2. TheViking
    Disconnect the battery, remove amplifier from vehicle. Remove cover from amp gaining accedd to the circuit board. using a tooth pick or similiar item, push the broken tip out from the back side of the rca jack........HOPEFULLY it open to the back side! if not.....Hmmmm
  3. aznboi3644
    could buy a neo magnet from radio shack for a couple dollars and see if that pulls it out...I'm not sure if the piece is ferrous though
