Noob question, couldnt find answer in basic tutorial
Discussion in 'General Car Audio Discussions' started by treeofmight1102, Oct 14, 2006.
  1. treeofmight1102
    treeofmight1102 New Member
    Hi,
    I have a 1993 buick regal, I am trying to install an after market stereo, the stereo is not powering on when I turn on the car, the manufacturer said the stereo is probably not grounded right.. I matched up and connected the ground cables ... what more can I do?
  2. aznboi3644
    Make sure the power connection are right...or make a new ground for the radio for security
  3. Rodny
    Rodny Full Member
    Check d power behind d radio make sure you have 12 volts at d red wire and d yellow. If you don't have power check d fuses.
  4. TheViking
    One more thing, the grey wire is NOT a ground, its the lighting!!!!!!!!!!
