Ok guys, I want you to pick the new DEFUALT theme for the new site I am working on here are the 8 I have narrowed it down to, the one that gets the most votes will be the new Defualt Skin (but I DO have VETO powers ) Theme 1 Can be "test Driven" here http://www.ibfskinned.com/test/?skinid=134 Theme 2 Can be "test Driven" here http://www.ibfskinned.com/test/?skinid=93 Theme 3 Can be "test Driven" here http://www.ibfskinned.com/test/?skinid=92 Theme 4 Can be "test Driven" here http://www.ibfskinned.com/test/?skinid=4 Theme 5 Can be "test Driven" here http://www.ibfskinned.com/test/?skinid=96 Theme 6 Can be "test Driven" here http://www.ibfskinned.com/test/?skinid=109 Theme 7 Can be "test Driven" here http://www.ibfskinned.com/test/?skinid=97 Theme8 Can be "test Driven" here http://www.ibfskinned.com/test/?skinid=94 you you dont like any of these, pic one that is close to what you like and make a suggestion for a change to that one
I voted for theme 5. Kind of has a SoundIllusions look. They all look pretty cool, except for theme 8, which looks kind of run of the mill. If these are skins, you could/should mix it up every once in a while. Maybe a different theme every month or two. When is the new site going to be up and when is shop4sound going to be up (I thought is was this month??)? BTW, I read on CAF that you're constructing 4 sites right now, in addition to working a full time job. Dude, you're going to kill yourself. Sleep is good. Anyways, good luck.
I didn't vote, because I have 2 I really like. 5 & 6 are the 2 I personally prefer. I like the theme on 4 (hey, I'm a metalhead... Skulls and crossbones are cool man ) but it is lacking contrast and is hard to read on the main pages.
well I have this site My New Store Have the Maintian and Fix thinsg with the Old Store because it is still active and then my Noise Organationion web site so that is 4 and then I have my FT job I have no Idea when I will have any of them done I am moving the Store to the Front though, at least I have the chace of Making some money with it My problem is that I never get one project done before starting another, I get 1/2 through and either get bored with it, or see soemthing I want to do with another site so I move to that one I need to displine myself and Get one site done, then move to the next and then move to the next one etc and 20 veiws and only 3 Votes all for differant ones?? All of them will probally be avaible to choose form at some point, but it will agian only be for the forum, there is not a portal solution that I like that use the full template eng, so I am going at it on my own agian, but when the Site is launch it will 100% functional, so it may take longer just because I have so much other shit going on
Text colors should not be hard to change it is the main image colors that are hard because many of these guys dont include the orginal files so you can edit them easly but changing the text to say white instead of grey should be easy,
