New look...
Discussion in 'General Car Audio Discussions' started by cccullen, Feb 20, 2009.
  1. cccullen
    I've been doing a lot of searching for ideas on what to do with the look of my set up. I have gathered some picture of the ones that I like.
    I'm thinking of mounting the amps behind the box this time. Any suggestions or comments?
  2. 2k Z71
    2k Z71 Full Member
    one problem with having the amps attached to the box is if your vehicle gets broken into it's a smash and grab job. instead of needing a screwdriver to get your amp out they just need to pull the wires off...but if you have a good allarm and have a safe place to park the vehicle you should be fine...depending on how much power your pushing you may also want to invest in a cooling fan if your amps are enclosed like they are in the pictures....if needed of course....just my 2cents
  3. pedro quiroga
    the first and second ones look very nice. do it!
  4. cccullen
    As soon as the box design is finished i'll get on it. I need more cargo space and with the false floor in there now i can use the back at all plus the fact that the false floor screwed up my amp.
