Well I found the First bug and I will try to get it worked out soon, but all of the "code" button on the reply and mew post screens will cause a "java runtime error" now this may not occur on everyones PC, but I know I get it so...... if you do just click the "help" button and there is a list of the code you will have the manually type them, until I fix the problem Also with the Error, if it askes you to "debug" just select no it is VERY annoying I know, and I will fix it asap.... also there is a new theme for all that like a "darker" look so what do you think about that one Sandt?
That one looks sweet. But I would make a final decision on this one. Its not good to keep changing skins, many people can be turned off by that.
HUH? I am going to keep the defualt DEFUALT I am not changing the look to that But I can add any number of skins to the forum and allow the USER to select what they want Right now there are 2 "Cat-Defualt" the White,and Grey theme and "Cat-Red" the Read and Black theme If you dont like the Defualt (as some dont) you can go to "my controls" and select "skins and lang's" and then pick the Cat Red
