new amp is wack
Discussion in 'General Car Audio Discussions' started by tepa13kreeper, Sep 7, 2008.
  1. tepa13kreeper
    tepa13kreeper Full Member
    i just installed my new amp its a alpine PDX-1.1000 and wired both w6v2 subs at 4ohms but when i put the volume up bass cuts off and than ill go back on its it the amp not strong or could it be my fuses i got a 80a agu under the hood and 80 agu in the back to the amp
  2. cccullen
    how many amps do you have? just the one? you alpine has a total of 80amp fuses so if you're only using the 1 amp then that should be ok. you may want to recheck your connections (power, ground etc.)
  3. tepa13kreeper
    i have 2 a jl audio 300/4 and the alpine pdx1.1000 and i just noticed its the amp that turns off when is to loud the light on it turns off i dont think they make anything bigger in agu fuses so what can i use in the front?
  4. cccullen
    I'd use at least an 120amp fuse under the hood. that should do the trick. if they don't have anything bigger than 80amp then just buy a new holder and use an ANL fuse and holder.
  5. tepa13kreeper
    ok thanks cccullen are the ANl fuse holders any good? or which one should i get?
  6. cccullen
  7. tepa13kreeper
    got new anl fuse holders under the hood and in the back and the amp stopped turning off thanks 4 the help at first i just bought the front one came home and my base turnned of it had melted the fuse holder in the back so i went back to the sound shop and they put anl fuse holder in the back to i guess the agu fuse holder i had sucked
  8. cccullen
    good to hear that everything is ok now.
