Need some help
Discussion in 'Car Stereo Amplifiers' started by l270ucas, Jun 20, 2009.
  1. l270ucas
    l270ucas New Member
    im new to the car audio world and i need some help. i have 2 jl audion 12w08 which have a rms of 125 watts each. i need to no if a 400 watt would give them to much power.
    thanks, lucas
  2. slapperz
    slapperz Full Member
    Well is the 400 watt 1/2/4CH? Wat impedence are you working with. Many factors before we could accurately answer
  3. pedro quiroga
    if you set the gain properly it will work just fine. also what slapperz asked.
    are the 12's 8ohm subs?
  4. l270ucas
    l270ucas New Member
    they are 8ohms. would a mono channel work better than multiple channels
  5. pedro quiroga
    both subs wired into a 4 ohm mono load. if that amp is a mono amp it will work fine if its a 2CH amp it will also work.
  6. l270ucas
    l270ucas New Member
    ok thnx going tomorrow to go pick it up
  7. pedro quiroga
    what amp are you getting?
  8. l270ucas
    l270ucas New Member
    i cant remember the name now but it is a 2 channel but i wirred it mono and 4 ohms. btw for some reason the subs wont work on cd but they work on radio. do you got any tips
