Need some advice..
Discussion in 'General Car Audio Discussions' started by Livinloud, Sep 15, 2009.
  1. Livinloud
    Livinloud Full Member
    Well im rolling in an elcamino.. i currently have 1 Memphis 12 in a ported big ass box running it to a 600watt rms offbrand amp.. i want to add another 12 i have everthing for it but lookin into a truck box is there any way to keep it bumping should the box be ported or what? im totally lost in all the port and sealed box thing i know that ported hit harder but not sure whether to get a ported truck box for 2 12s or unported truck box any advice would be magical
  2. cccullen
    if you really want it to bump good then stay with a ported box. what are the exact models of your memphis subs? ARe you just gonna add another memphis or are you going with a different brand?
  3. Livinloud
    same subs and pr13 i believe with a offbrand amp i bought from a friend..
    and yes the same of another sub i want to put in 2 12 truck box behind my seat any certain way to port it?
  4. cccullen
    you could do a downfiring sub set up. not sure how much space it will take up though. what kind of space do you have to play with in the back? What are the exact models of your memphis subs so i can look at the space requirements?
  5. Livinloud
  6. Livinloud
  7. Z400
    Z400 Full Member
    So you tell us you want to add another memphis sub, same model and size as the one you already have.
    We give you advice on the box, and then you buy a Kicker cvr sub?
    Im confused.
    Sounds like to me your making undecided decisions already which are going to cost you in the long run.
    Plan something out and stick with an idea that will work.
