Need Help
Discussion in 'Subwoofer Box and Custom Fabrication' started by t5munoz, Feb 9, 2008.
  1. t5munoz
    t5munoz Full Member
    Can anyone help me with some demensions for 4, 8in solo barics L7 going in a single cab 1989 chevy 1500, i am going seald for SQ so help me out please!!!
  2. electrolytic
    electrolytic Full Member
    Hey can you make another thread and use the title i sent, it will help the site. Will be a good thread.
  3. electrolytic
    Ok, nevermind lol let's see if we can make this hit. Which model are you getting 2008? And what ohms are they.
    Kicker solobaric S8L7 Car Stereo Subwoofers Theile Parameters Manual Specifications Subwoofer Box Sealed Enclosure
  4. electrolytic
    You will have to measure how much room you have to work with also.
  5. electrolytic
    Kicker solobaric S8L7 Car Stereo Subwoofers Theile Parameters Manual Specifications Subwoofer Box Sealed Vented Enclosure L5 CompVR
    S8L7-2008-MODEL
    SealedCompact (MinimumEnclosureVolume)
    .33 ft3 (9.34L) Power Handling = 200W RMS
    SealedSQ (MaximumEnclosureVolume)
    .75 ft3 (21.24L) Power Handling = 200W RMS
    VentedCompact (MinimumEnclosureVolume)
    .66ft3 (18.7L) + port displacement
    1.5 x 9.5” (3.8x24cm) port, 19.25” (49cm) long
    Power Handling = 375W RMS
    VentedSPL/DeepBass (MaximumEnclosureVolume)
    1.0 ft3 (28.3L) + port displacement
    2 x 9.5” (5.1x24cm) port, 21.25” (54cm) long
    Nominal Impedance [Zn], ohm [per coil] 2 or 4
    Resonance Frequency [fs], Hz 47.2
    Power Handling Watts, Peak (RMS) 900 (450)
    Total Q-Factor [Qts] .644
    Equivalent Volume [Vas], ft3 (L) .36 (10.3)
    Outer Frame Dimension, in (cm) 8 13/16 (22.4)
    Mounting Depth, in (cm) 4 3/4 (12.1)
  6. t5munoz
    t5munoz Full Member
    They will be 8"L7 d2 and of course with minimal space in a single cab i need to use close to the .33 cubic sealed for sound quaility.
  7. electrolytic
    Ok, you have to be very specific, are they brand new 2008 model, because the specs are different foR say a 2007 model S8L7. Also if you can measure exactly how much space you have i can take those measurements and put them in a program with the specifications for your subs and then i can give you the best size and output for this. Maybe azn can run it through his program also if he's bored lol.
  8. electrolytic
    ......................................Kicker S8L7
  9. t5munoz
    t5munoz Full Member
    They are going to be last years model and i will wire them in pairs at four ohm load per pair i am using ppi amps and they are at their best at a four ohm load bridged
  10. electrolytic
    ok, oh cool you made another thread with kicker in the title, watch that thread go to the top wohooooo lol. Let's switch to that one.
