need help trouble shooting a memphis mc1000d amp
Discussion in 'Car Stereo Amplifiers' started by Pwnstar, Jul 26, 2010.
  1. Pwnstar
    Pwnstar Full Member
    hi guys like the title says i need help trouble shooting a memphis mc 1000d the amp was working fine and one day it had a fuse fault it wasent being pused or anything just blew the fuses and now every time i replace the fuses that blow and then it back to fuse fault its not going into protect just fuse fault and i opened the amp up and there is no burn marks or anything where the amp blow up at like iv seen in all my other amps can somone tell me what the problem might be or is the amp fryed? and if u could email me at Pwnstar101@verizon.net
    ________
    starcraft replays
  2. fstrfvo
    fstrfvo Full Member
    Check your power wire from front to back, it might be touching metal somewhere and causing a short.
  3. Pwnstar
    Pwnstar Full Member
    ok i just completly rewired my car but i have not tryed it yet, but what do you think the ods are its blown up? or dose it sound like a wireing issue?
    ________
    WR450
  4. fstrfvo
    fstrfvo Full Member
    to me it sounds like a short somehwere, thats what the fuses are there for, to protect your car and equipment.
  5. ericj
    ericj Full Member
    It could also be a problem within the amp, such as a faulty FET or output transistor. It might be a good idea to check the remote wire for a short, too.
  6. Pwnstar
    Pwnstar Full Member
    ok like i said the car has been rewired and all the amp wires and remote replaced so shouldent be any shorts but as far as an FET or an output transistor what are those and can thay be replaced? maby some pics of what im looking for
    ________
    iolite vaporizer
  7. Zschase42
    Zschase42 Member
    I had the same problem before and mine was blowing because i had it bridged to a sub which was causing it to blow it fried my sub and i sold the amp to a buddy he runs it on 2 subs works better than ever
