Need help building a box
Discussion in 'Subwoofer Box and Custom Fabrication' started by Ivancho, May 17, 2007.
  1. Ivancho
    Ivancho Full Member
    I have an Alpine Type R 12" (SWR1222D) I have tools and time to build a box but I have no clue on what size it needs to be, I've got the specs from alpine but i'm confused because people who have built boxes before are giving different specs from hands on experience. Does anyone have any advice on what size box I should build the box and where can I get the specs? This will be very helpfull.
    PS: I have never biuld a box before, so go easy on me.. Thanx :D
  2. electrolytic
    electrolytic Full Member
    Welcome !!
  3. G3n3R@1
    G3n3R@1 Full Member
    azn where u at?!!?
  4. electrolytic
  5. Ranger SVO
    Acorrding to the link supplied by Electrolytic, you sub will work in either a sealed or ported enclosure. For sealed it recommends 0.6 to 1.0 Cu Ft. I would personally shoot for close to 1.0 cu ft
    For ported it recommends between .075 and 2.0 cu ft. I'm gonna tell you that anything less than 1.5 won't work. Now 2.0 would be the minimum size I would recommend, lets shoot for closer to 2.5. Not much above the recommendation but it will ge me something to work with. Can you post the specs from Alpine, it would be helpful.
  6. G3n3R@1
    G3n3R@1 Full Member
    also how much room do you have where you're putting your enclosure? is it in a car trunk or back of an SUV....
  7. Ivancho
    Ivancho Full Member
    This is going on a 01 malibu
    The specs from Alpine are:
    External Dimensions 1.7CF 18x13.5x16
    Vent 12, 1.25W, 22.75L
    Tuning Point 36Mz
    does anyone know of somewhere I can get the measurements of a box
  8. Ivancho
    Ivancho Full Member
  9. aznboi3644
    sorry guys...I was studying for finals.
    What kind of bass do you want first???
    This will determine box size and tuning
  10. Ivancho
    Ivancho Full Member
    I just want something that sound good, I listen to rap music
    What do you think about this measurements, and does the speakers needs to be at the right?
    this box is: 2.0CF 32Mhz
  11. electrolytic
    I can't find the specs on that sub, seems to be from europe or something, i tried last night, i found specs for swr1221 don't know if it's the same. Maybe email alpine ask them for the manual/specs
  12. electrolytic
    The box needs to be custom designed specifically for your sub if you want it done right. Need the full specs of the sub...
    should look like this.
    Model: SledgeBeast 6000
    Fs (Hz): 17
    Qms: 9
    Vas (liters): 245
    Cms (mm/N): 0.254
    Mms (g): 345.1
    Rms (kg/s) 4.095
    Xmax (mm): 16
    Dia (mm): 323.9
    Sd (sq.cm): 824
    Vd (liters): 1.32
  13. G3n3R@1
    G3n3R@1 Full Member
    haha i can't believe i googled SledgeBeast 6000. wow.
  14. electrolytic
    lol, didn't find it?
  15. G3n3R@1
    G3n3R@1 Full Member
    google told me to fsuck myself.
  16. Ivancho
    Ivancho Full Member
  17. Ivancho
    Ivancho Full Member
    Ok, guys thanks for the info so far I came up with some calculations and this are the results let me know what you think, to me the box looks small..
  18. aznboi3644
    What vehicle??
    For that sub and rap...2.5 cu ft tuned to 40Hz will BEAT HARD
  19. Ivancho
    Ivancho Full Member
    this is going in to a chevy malibu. what about the 2.0 @ 32Mhz picture on top, you think that will work?
  20. aznboi3644
    that will not work at all...Tuning a box for a sub to 32MHz is nearly impossible.
    But 2 cu ft tuned to 32Hz will be good. For rap though I'd do 2.5 cu ft tuned to 35hz...it'll be louder and still sound good.
    But that is my opinion only
