Need Help A.S.A.P. , hooked up in dash mp3 player and get no sound
Discussion in 'General Car Audio Discussions' started by mccoyxx, Sep 18, 2009.
  1. mccoyxx
    mccoyxx New Member
    Hello everyone , I am at a loss for words on what happened to me earlier today. I purchased a 96 Ford Explorer Sport yesterday and wanted to change the CD player out and put in my mp3 deck. I removed the old Sony CD unit and unplugged the harnesses, then took the Sony mp3 harness and wired everything up. When I tried to test the mp3 unit it came on and lit up and functioned properly, but I had no sound at all :(. This unit is almost brand new and was working perfectly in my S-10 I removed it from earlier today. I have rechecked all of my wiring and everything is connected color to color on the harnesses, connections are soldered with shrink tubing and no fuses are blown. I ran a seperate ground straight to the battery and checked it and still nothing. The CD player and the mp3 player worked fine until I switched them and when the mp3 didn't have any sound I switched the CD unit back and now it has no sound either. The factory wiring hasn't been cut and all is as it should be except for the sound. Please if anyone knows what is going on here let me know as I am clueless. Thanks for your time ... RSM
  2. cccullen
    Welcome...
    One question for you... Does your explorer have a factory amp? I know that if you have the upgraded sound system that it will come with a factory amp. if there is a factory amp in there then you'll have to bypass it for the system to work.
  3. mccoyxx
    mccoyxx New Member
    I am uncertain, however I wouldn't imagine it would have for the CD unit to have been working when removed. I will check to make sure though ... thanks !!
  4. Lazy Eye
    Lazy Eye Full Member
    It may be a faulty wiring harness I had that happen to me before. I would get a new one and try that
  5. mccoyxx
    mccoyxx New Member
    Got it !! ... appears you were right, they had it wired straight to the battery before I hooked it up correctly .... had a factory amp mounted under the passengers side rear panel in the hatch ... took the amp loose and re-wired everything ... works great :D
