Need Enclosure answers
Discussion in 'Subwoofer Box and Custom Fabrication' started by LouderisBetter1, Jan 21, 2010.
  1. LouderisBetter1
    LouderisBetter1 New Member
    I dont need help. I need a Answer
    ok im not beating around the bush because I've tried to figure this thing out but its just not happening for me.
    I Have a 2.7cbft Box (Net Volume) I have 3- 10" Pioneer Premier Champion Pro subs inside of it. It is a Common CHamber Box and I am willing to do 1 or 2 ports.
    The Round Port Suggestion for the subwoofers are here (IM sure thats single Chamber suggestions)
    0.9cbft 3 x 3.5 (inch)
    1.2cbft 2 x 2.5 (inch)
    0.6cbft 3 x 7 (inch)
    Resonance frequency is 34.7hz
    Xmax 11mm
    But I have a common chamber because im building under a truck seat and it has alot of bumps and grooves.
    There's the manual if that helps any. I just want some suggestion on NET port size HxWxD thanks
    http://www.pioneerelectronics.com/St...Manual1120.pdf
