I just bought a 12" dual 2 ohm kicker L5 square sub. 600W rms 1200Wpeak. I will be buying from www.sonicelectronix.com could u please help me find a proper amp to power my sub. I want it so i can crank it and still be comfortable knowing its not going to blow, thanks!!
what's your budget for the amp? the moderator here is selling a elemental designs NINe.1 amp. that would give you 450watts at 4 ohms. you can only wire your amp at either a 1ohm or 4ohm configuration. 450watts doesn't sound much but that's at 12.5V so at 14.4 that should put out close to 600watts. this amp is a beast, at 1ohm it will but out a good 1500watts so that will leave you a lot of room to grow with...
