Need advice on which alarm system/remote start system to get
Discussion in 'Car Alarm, Remote Start and other Accessories.' started by affiatati7, Mar 9, 2009.
  1. affiatati7
    affiatati7 Guest
    I would like to install a security system with remote start in an '09 Jeep 2 door Wrangler. I am looking at 2 way LED or OLED systems with a one mile range.
    My first question is what are the advantages/disadvantages of LCD and OLCD? easy/difficult to see day/night?
    Also, I guess seeing the display day or night is another important feature
    I was looking at these systems:
    1- Prestige XR09100
    2-Autopage RS-1000 OLED
    3- Viper 5901 Responder
    4- Python 1090
    Here are some features I would like to have:
    1- What is activation/deactivation distance?
    2- Large remote display? Easy to see day/night
    3- Does remote open doors and tailgate separately or all together?
    4- When canvas is down can alarm sense an intrusion via shock sensor?
    5- How does sensor adjust? Via remote?
    6- Does remote inform when car has started? How?
    7- Large remote display? Easy to see day/night
    8- Does system show temperature of inside vehicle?
    9- Can I extend the run time of engine if needed?
    10- Does remote show countdown of how long engine will run before shutdown?
    11- Does remote give visual and audible warnings? For which features?
    12- Can the remote starter feature shut off engine manually?
    13- Can I activate the alarm remotely with display showing activation?
    14- Does unit have a multi tone siren?
    15- Parking meter timer?
  2. DMP
    DMP Full Member
    You will like the OLED alot better than the regular LCD. Its alot more "high tech". I have the Prestige you listed. Also, Code Alarm has one. Its the SRT9000. Ive installed a few of those before.
    1- What is activation/deactivation distance? I think most or all of them are 1 mile that you listed. But you wont get that kind of range because of different factors. I still recommend a 1 mile tho.
    2- Large remote display? Easy to see day/night Yes.
    3- Does remote open doors and tailgate separately or all together? It will unlock all doors and that includes tailgate.
    4- When canvas is down can alarm sense an intrusion via shock sensor? ???
    5- How does sensor adjust? Via remote? Depends on the alarm. Some adjust on the sensor itself, but not the remote.
    6- Does remote inform when car has started? How? Yes. It shows a display.
    7- Large remote display? Easy to see day/night Yes.
    8- Does system show temperature of inside vehicle? Some. Read the specs.
    9- Can I extend the run time of engine if needed? Yes.
    10- Does remote show countdown of how long engine will run before shutdown? I dont think so.
    11- Does remote give visual and audible warnings? For which features? Yes...for alot of them.
    12- Can the remote starter feature shut off engine manually? Yes.
    13- Can I activate the alarm remotely with display showing activation? Yes.
    14- Does unit have a multi tone siren? Depends on the system. I dont bother with the siren and hook it up to the horn.
    15- Parking meter timer? Some.
    I suggest reading the specs on those systems. It will tell you what it does. All of those are good systems.
  3. 2k Z71
    2k Z71 Full Member
    I think he's talking about a tonneau cover correct? If so you would need some type of door/hood switch that will react differently to the cover being opened or closed. Not very hard to do....
  4. Lazy Eye
    Lazy Eye Full Member
    or maybe he meant if it was a convertabe?
  5. 2k Z71
    2k Z71 Full Member
    true....didn't think about that
