My System
Discussion in 'Car Subwoofers' started by DrazyHaze, Jan 24, 2010.
  1. DrazyHaze
    DrazyHaze Member
    So, i think i've figured out the system i want.
    I'm gonna get two 12'' Kicker Solo-Baric L5 Series Subs. (4-OHM)
    My Amp i think will be a JL Audio 1,000 Watt at 1 OHM.
    I was told to wire my subs parallel into a 1 OHM so they receive the most power possible.
    What would you guys recommend?
  2. MitaG3
    MitaG3 Full Member
    That sounds perfect. Should sound real nice in a good box
  3. DrazyHaze
    DrazyHaze Member
    do you recommend building my own box? or buying one?
  4. jonnyv713
    build it!!!
  5. Kvo_8
    Kvo_8 Full Member
    if you get the jl 1000/1, it delivers 1000 rms at 4 ohms, 2ohms, and 1ohm. also its constant 1000 watts between 11v-14.4v i believe...its pretty awesome :)
  6. MitaG3
    MitaG3 Full Member
    definitely build one! it is an enormous difference. you'll never forgive yourself if you get a pre-fab box
  7. jayz85
    jayz85 Full Member
    jl 1000/1's are only 1.5ohm stable....
  8. Kvo_8
    Kvo_8 Full Member
    hmm i never knew that lmao. i run mine at 1 ohm all day. i got a dc lvl 4 15", dual 2 ohm, wired down to 1 ohm.
  9. jayz85
    jayz85 Full Member
    well thats what I read... but then again its hard to figure what our real impendance load is...
  10. pedro quiroga
    i was just going to say that too, maybe his imp rise is compensating for it.
    hell my nine.5 has a .7 ohm load but my rise is at 2.1 ohms.
  11. jonnyv713
    how do u find your rise?
  12. pedro quiroga
    i had a friend do it. you'll need a clamp meter and DMM.
    you measure the voltage going in to the speaker wire then the voltage at the amp.
    he did it, and there was math and i forget. :huh:......yeah so im no help right now..lol.
    after that he divide my reading to get me 2.1 ohms at 50HZ or something.
    all i know is that he said the bigger the box the lower the imp rise.
    now i have to google it to know.
