Product Website: Virtins Technology: Turn a PC into Virtual Instrument - Home Download PC version: http://www.virtins.com/MIsetup.exe Download Pocket PC version: http://www.virtins.com/PocketINSSetup.exe Multi-Instrument is a powerful sound card based multi-function virtual instrument software. It features a specially designed data acquisition approach, which is able to monitor the input signal continuously without missing any trigger event before a frame of data is collected. It has a very fast screen refresh rate (typically greater than 50 frames per second). It supports sophisticated triggering method including pre-trigger and post-trigger,level trigger and differential trigger. It Supports 8, 16, 24 bits and multilingual user interface, including English, French, German, Italian, Spanish, Portuguese, Russian, Simplified Chinese, Traditional Chinese, Japanese, and Korean. A comprehensive range of functions are provided, including: (1) Oscilloscope Dual-trace waveform, Waveform addition and subtraction, Lissajous Pattern, transient/long-time signal recording, voltmeter. Various digital filters are supported. (2) Spectrum Analyzer RMS amplitude spectrum, relative amplitude spectrum, octave analysis (1/1,1/3,1/6,1/12,1/24), frequency compensation, frequency weighting (A,B,C,ITU-R 468), peak hold, averaging, measurement of THD, THD+N, SNR, SINAD, Noise Level, IMD, Bandwidth and Crosstalk, phase spectrum, auto correlation function, cross correlation function, coherence function, transfer function (Bode plot), impulse response. Support 55 window functions and window overlap. (3) Signal Generator Function generation, multitone generation, arbitrary waveform generation, burst tone generation, MLS generation, DTMF generation, musical scale generation, white noise and pink noise generation, and frequency/amplitude sweep. Synchronized operation between the signal generator and the oscilloscope is supported. (4) Multimeter voltmeter, sound pressure level meter(dB, dBA, dBB, dBC), frequency counter, RPM meter, counter, duty cycle meter, F/V converter. The counter trigger level and hysteresis can be adjusted. (5) Spectrum 3D Plot It is used to trace the spectrum variation with time. Two types of plots are provided: waterfall and spectrogram, with adjustable tilt angle of T axis, adjustable height of Y axis, and selectable color palettes. (6) Data Logger It provides long time data logging function for 93 derived variables, including RMS value, Peak Frequency, Sound Pressure Level, RPM, THD, etc. Up to eight data logger windows can be opened and each window can trace up to 8 variables. The logged data files can be reloaded into the data logger for review. (7) LCR meter It is used to measure the value of an inductor, a capacitor or a resistor, or the impedance of a network of them. (8) Device Test Plan Device Test Plan provides a mechanism for you to configure and conduct your own device test steps. It takes the advantage of the sound card’s capability of simultaneous input & output, to generate a stimulus to the Device Under Test (DUT) and acquire the response from that device at the same time. Different stimuli can be generated and the response can be analyzed in different ways. It supports 13 instructions with corresponding parameters. System Requirement PC or Laptop with 8, 16 or 24 bit Windows compatible sound card, Microsoft Windows95 or greater, Microsoft NT or greater. Screen resolution is recommended to be greater than 800 × 600 pixels.
