mtx 4000 box help
Discussion in 'Car Subwoofers' started by magnum340, Oct 20, 2007.
  1. magnum340
    magnum340 Full Member
    well guys im asking for quite a bit of help here, id like to build a ported box for my mtx 4000 12in sub, i got it about 4yrs ago. i googled the sub but had no luck. what im looking for is the cubic feet for the box, how big is it suposed to be? also the size of the port, wow im pretty much asking someone to do everything but build it. well any help would be awsome.
  2. mrmizcue
    mrmizcue Full Member
    all the info should be here. i would have posted it but did not know which 12" 4000 you have.
    MTX Car Audio - Archive
  3. kevscaraudio
    kevscaraudio Full Member
    hi
    i would make the box 1.75 cu/ft personally with a 4"x6" port
  4. magnum340
    4x6 is that 4 hight and 6 depth what about length? hope this isnt a lame question
  5. magnum340
    i get the whole 1.75, but the 4x6? can i get some help
  6. magnum340
    i was hopeing to buld the box this morning. if i could get an explanation.thanx..
  7. aznboi3644
    i'm sure he means a 4 inch round port 6 inches long but that would make it tuned around 45Hz which is too high
    I'd say to start build a 2.2 cu ft box tuned to 40 hz with a 4 inch round port that is about 7 inch long port
  8. magnum340
    well i built a 1.75 box with a 4x4 port 6 in long.(not round). sounds good on low notes but kinda sucks or (flutters) on higher notes. can someone explaine?
  9. aznboi3644
    well your box is tuned around 46 Hz
    pretty high for daily driving
    Try turning the gain down and see how it sounds...could be the amp clipping or port noise
  10. magnum340
    well..... the thing is the box is in my home. and i do understand its a car woofer, but it sure did have the ladies shaking there asses at my hollowing party. i shouldnt have waited to the last minet to ask for help, but i built it that saturday morning! so at low volumes it sound good even at high volumes low notes sounds good just those high notes, sounds like a stock 6.5 crapy mid woofer.
  11. aznboi3644
    is the noise coming from the port??
  12. magnum340
    um.... not sure. is there a difrence? where ells can it be comming from, and what would it mean?
  13. aznboi3644
    have you tried turning down the bass and seeing if the fluttering is still there??
    have you tried moving the box around???
    Could be cancellation
