Mono amp question
Discussion in 'Car Stereo Amplifiers' started by bkellar81, Jun 6, 2008.
  1. bkellar81
    bkellar81 Full Member
    If a mono amp is rated 300 rms and i hooked up 2 subs would both subs be getting 300 rms each or would they split it and only get 150 rms each?
    The subs are 2 boston g21244 and the amp is an kenwood excelon kacx10d if that helps at all. Thanks for helping!!
  2. cccullen
    if your amp is rated a 300 rms and you have 2 subs then they would only be getting 150 watts rms each.
    But the kenwood amp puts out 600 watts at 1ohm at 14.4v. so if you get 2 subs dual voice coil 4ohms then you can put a total of 600 watts to those subs meaning 300 watts per sub.
    the BA G212-44's are DVC 4ohm so you can run them at 1ohm. perfect match cuz they are 300 watts rms a piece.
  3. bkellar81
    thanks. it sounds like a perfect match. Hopefully the installer knows that.
  4. cccullen
    just make sure he wires the 2 subs into a 1ohm load. here's a diagram:
