I have a kicker cvx 12" hooked up to a rockford 501s(1500 watt, 2 channel). My sub is 4 ohms. It bumps pretty hard but only for about 10 minutes before it cuts out. I was told that I have a mixmatched sub and amp. Does anyone know if this is true? Suggestions?
Means your amp cannot handle the impedance load...what impedance is the sub??? I'm sure the CVX's are not single coil...but at the same time I'm not sure.
Could be to low af an impedance for the amp Could be poor Gound Could be poor electrical system Could be you dont know the limit of your system Could be the amp is junk Could be the tensile leads shorting out Could be head unit Could be ..........etc.....................
