Mach 5 Audio MAW-15
Discussion in 'Car Subwoofers' started by jmenace_thakidd, Aug 21, 2007.
  1. jmenace_thakidd
    jmenace_thakidd Full Member
    im gonna be ordering one soon just wanted to know if anyone has heard or dealt with Mach 5 Audio here are the T/S Parameters any input is appreciated i will also post up vids when it arrives
    Fs = 26 Hz
    Re = 8 Ohms
    Qes = 0.35
    Qms = 3.35
    Qts = 0.32
    Mms = 232.8 grams
    Rms = 11.42 kg/s
    Cms = 0.159 mm/N
    VAS = 129 litres
    Sd = 756.3 cm2
    Xmax = 13 mm
    Cone Diameter = 31.1 cm
  2. aznboi3644
    I want one to play with...but money is a problem
    damn good subs for the money though
  3. jmenace_thakidd
    no help i know someone out there can help
  4. jmenace_thakidd
    the box i built for my P3 is tuned to 37hz do you think that box will be ok to put the MAW-15 in or should i build another one
  5. aznboi3644
    from WinISD i like the look of 3.8 cubes tuned to 35Hz.
    does that help??
  6. mrmizcue
    mrmizcue Full Member
    with the information suppied....according to BB6Pro your output will be less with the new sub than with the P3...unless i am doing something wrong....which could be the case
  7. jmenace_thakidd
    mrmizcue do youhave the Parameters for the p315
    cause when i put them in WinIsd it said the P3 was more peaky with a little less out put unless im doing some thing wrong
  8. aznboi3644
    ok here is the comparison with your box and both subs in the same box
    the Mach 5 will have less output but a hella lot more sound quality..the P3 has a high qts...it is more boomy and sloppy
  9. jmenace_thakidd
    ok kool im gonna buy it this week hopefully it will be here middle next week ill post some vids when i install it i might end up building another box for it anyway
  10. mrmizcue
    i used the spec's that is in bassbox...pre-loaded
  11. jmenace_thakidd
    ok i definately gotta get that program
  12. deadz67
    deadz67 Full Member
    i know a buddy who has 2 mach 5 10`s in his Corolla trunk in custom fabbed sauna tube( yep ,for concrete) with a punch amp pushin it & it POUNDS!!!
  13. Lazy Eye
    Lazy Eye Full Member
    This thread is 2 years old dude...
    lol
  14. deadz67
    deadz67 Full Member
    yeah but, his mach 5`s aren`t.....lol
